Help! Major electrical problem.
colbystephens
1 ton status
Oregon
Got in my truck this afternoon to move it, turned on my fuel, cold timing advance and ignition key (all those things have their own switches + relays + fuses). Pressed the glow-plug button, GP relay clicked on and suddenly all electrical power to my truck was gone. Let it sit a moment, tried again, same thing happened. Now, nothing at all. No headlights, no heater fan - nothing.
I drove the truck just last Saturday. Been doing the wiring this way for almost 2 years now. I have no idea where to start. I'm assuming it's a fusible link somewhere. Can y'all tell me where the likely ones are to start checking? How do I check a fusible link for failure?
:doah:I was going to go wheelin tomorrow! Dammit! :(
update: i haven't done a damn thing to the wiring/electrical on the truck. after letting it sit for a couple hours, I turned the key and had power again. headlights turned on, etc. i didn't push the glow plugs because i figured that would pop it all off again...
+1 on grounds or batt connections.
Had an issue like that was caused by a bad ground off battery.
Ign on truck was fine everything worked, then when i put a load like turned my stereo up, or tried to start it it would have same symptom. Totally dead.
ok. that's encouraging, because it'll be an easy fix. thanks!!! :bow:
not necessarily easy to hunt down, but it'll be cheap!
You said all the things you switched on had fuses. Is there a self resetting circuit breaker in there anywhere?
Fusible links and fuses don't repair themselves and supply power a few minutes later.
Loose connections on the battery can sometimes do that, but it sure sounds like a CB with a shorted glowplug.
J.
no circuit breaker that I'm aware of. I'm betting it's battery cable related. I've been attaching and un-attaching my battery alot recently for welding...
That's probably what did it right there....
My truck would do something similar; I'd open the doors and the dome lights would be off, radio wouldn't work, and fuel pumps wouldn't turn on, but the truck would crank.
No fuses were blown; I did a visual inspection under the hood until I shook some wires and realized that the PO had piggy backed off the + terminal of the alternator for a 12v constant! That wire had a weak connection at the terminal and would cut in and out, say, if I slammed the front door or hood etc.
I moved it to it's own spot on the battery and all is well.
