apache
Hey guys I need some advice on a new project which is a 85 2500 Sub 4x4,350,400,208 T case. First order is suspension and I need some advice on going 4" or 6". I plan on using 4 new springs either way but wanted to ask if 6" will be to much and cause lift related problems. Id like to avoid driveline issues and dont care to drop the TC to ease up angles. It will be used for desert exploration,camping,and it will get used but not abused, will be running stock rims probably with 285`s or 305`s,winch up front and probably a fabbed rear bumper/carrier so there will be some xtra weight at both ends. Also any reccomendations on specific systems would be appricated. Cant wait to get this thing goin
Thank you.
Thank you.
