Help me diagnose
Mastiff
Tucson, AZ
I have an 83 K5 with TH400, NP208. I accelerated hard today and BAM! (loud noise) and then no drive. The engine is happy, but no movement in any gear or transfer case position. I wasn't smart enough to engage the front hubs to see if I could move with only the front, just thought of that. The thing just rolls around like it's in neutral, but I did determine that the front shaft is free in 2x but can't rotate in 4x when parked.
Any ideas on what might have blown, what to check for? I assume a trip to the shop is in my future, but I'd like to know what's up before I go in. My first thought was a busted chain, but I think I read that that would only affect the front drive? Hopefully it's not the trans itself... I thought 400's were bulletproof. :doah:
208 tcases like to go boom when thay are worn out .
i had 1 go bang on a hard street take off in 2wd. only way i could get it to go was 4low. lucky i was 1/8 mile from friends shop.
pulled the drain plug from tcase and found lots of parts with oil.
I've got no front or rear drive it turns out. Don't know if my problem is trans or T-case at this point.
Turns out it was the TH400 output shaft. There goes $750 I'll never get back. :mad:
