I want to be lazy, I would like someone to enable me in being so.
I'm currently running a 32 spline 465/205 non-slip yoke setup. All that stuff out of '85+ one tons, if it matters.
I'm running a driveshaft I won here years back. My driveline angle is bad. Turned the axle up before I knew better, so t-case output is "stock", pinion is pointed up. Perfect for CV, but I don't have a CV.
Plan is to convert to a 465/241 setup with SYE (http://www.jbconversions.com/products/sye/np241c_std_sye.php) and CV.
What is the best way to go CV with the SYE kit? Buy the 1350 flanged setup and work with someone to get a CV that mates up to it? I'm going to have to have a shaft made one way or the other, might as well do it right the first time.
I was going to use the flange mount to a 1350 cv not cheap but nice.
