So I have had some problems now since i converted to manual hubs. I always drive around in 2wd and unlocked unless it snows when I lock my hubs but I go to drive on the highway and reguardless if I'm in 2hi or 4hi I can't go much over 55mph because the vibrations are so bad. So I have to unlock to drive down the highway then when i get off i have to lock them again, btw I hate the whole get out of your truck thing it sucks I miss my auto hubs very much.
Anyways i looked underneath to find that the foward ujoint on the front drive shaft is very loose. In taking a closer look and after replacing the ujoint, there is about a 1/4" of play between the nubs on the diff yoke. The ujoint is a brand new autozone unit so wtf?
As well the slip joint on the front drive shaft I can wiggle around a little is that bad?
Also I know the passenger side axel ujoint is bad but i dont think it could creat that much vibes. Also the cv joint is still pretty solid but again has seen better days.
One more question, is there supposed to be some sort of thrust washer or something inside the spindle to help locate the front axel shafts?
