Help me find this replacement part?
2_wacko
Texas
I have a 87 chevrolet with a 305. Its the hose that go's from the back of the intake manifold to the heater core? It has this # 093086 on the hose.
is the hose cracked?find a local place that does hydrolic hoses they can pop the ends off and put new hose in and pop the ends back on
Yeah I might have to no luck finding it at the auto parts stores or online.
Remove the screw in clip style fitting in the intake, replace with a screw in hose fitting. Then replace the whole hose with standard heater hose from the parts store. Never have trouble finding a replacement again.
Ok I cut the metal part that had the leak, and ran heater hose from there no more leaks thanks everyone for the input.:woot:
Yep, ended up just removing the hose, removing the fitting from the intake, and screwing in a nipple adapter so I can run standard 3/4 inch heater hose.
All in all it cost me about $15 and now I can make a repair on the road if a heater hose ever bursts.
read this thread :waytogo:
