help me pick a carb
NoSmog73
lodi,ca
Hi again I have a 73 blazer 350 that isn't really modified and want to get rid of the rodchester and need some helpful insite.What is the better carb,the carter 9635 electeric choke(625 cfm) ,carter 9755(750 elec choke) or the edelbrock 1460 (600cfm elect. choke)
Everything but Quads suck! nobody here will tell you any different. The only thing that beats a quad is fuel injection.
Get the Eddle brock Rochester with electric choke.1904 is the model number. Hit the junkyard and get a air cleaner off about a 85. Also get the choke oil pressure switch and wires or buy the one in Jegs listed as a fuel pump cut off. That is the correct way to wire a electric choke. it will only send power to the choke when it's got oil pressure/running. You want the 85 air cleaner because it has a connection normal used for the air pump. It's a pipe up into the clean air side of the air cleaner. you need to run a peice of hose from the float bowle vent (front top center big port on the carb) to that pipe to vent the float bowl properly.
Women dig dents and flat paint!
<a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
75 Jimmy, Dollar
Grim-Reaper
1900 series edelbrock Q-JET. do a search you;ll find a lot.
ARQ.
offroad baja!!!
72 4x4 CST Blazer
71 4x4 CST Blazer
<a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
Yep, what they said. Only the Q-Jet will run right at extreme angles and when you are bouncing around hard. Anything else will die. Do a search, this has been covered again, and again, and again, and...
Russ
85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
ive been in some crazy off camber angles in my jimmy and never had it stall ive even had people ask if i have fuel injection and the answer was "just a Q-Jet" you gotta love it. Now if you want street performance go Holley. Now if you want looks go edelbrock. just my .02
<font color=purple>I put the Panic in Hispanic</font color=purple>
<a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
Ya, I'm with them. I have run my quad at some high angles, and only had a problem once. I was on a REALLY steep hillclimb and it wanted to die once in a while, but i just floored it and it ran me right to the top. I have run many other off camber and steep runs with no problems. It is the best fourwheeling carb around. Barn none. It is the only way to go if you offroad.
My Chevy isn't broken, its just out of gas.
I just put a 1406 on my truck and for the street i like it a lot more than my stock q-jet, havnt tried it off road though. I would like to get a edelbrock q-jet though
My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
1406 is great on road...any sort of angle and it floods out though. I'd get either a Q-jet or FI if you wheel it at all.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
I got a new edlebrock 750 "1407" fo sale. just cant use it in CA
If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
75 Jimmy 11" lift with 40's
Hi XPLOSUV I will be going to the 4x4 camping weekend on the 9th,10th and 11 to so I can chat with ya if you still have it by then.Is it not (smog compatible) for the 75 since you still have to get the smog every 2 years.I have a 73
Yea the Kalifornicaton Laws wont allow me to use it and Im giving up playing the games every 2 years. I'll see ya up there.
750 is way too big of a carb for a 350.
If I were you I'd go with a new Q-jet.
That said, I have a 500 CFM Edelbrock on my 305 and it works very well. Future plans are to rebuilt the old Q-jet for performance and pop 'er back on. My 305 is not stock, but doesn't need any more than a 500 cfm carb. A 600 cfm would work great on a 350.
Tim
'84 Chevy K10, lifted, loud, fast, and 3/4 ton axles
750 CFM too big for a 350 ????????????
I think someone should tell GM that they made a grevious error on all those millions and millions of 350s that they put 750cfm Q- JETs on.
Every Q Jet after the late 1960s that GM has put on any of their vehicles was 750 CFM or larger.
True, 750 CFM Holley or Edelbrock /AFB type wont work well on most 350s. But the small primaries and the huge secondaries allow the Q-Jet to work very well on a smaller displacement engine.
As far as the choice between Edelbrock and Carter it dosn't matter they are both basicly the same carb. They are both based on the Carter AFB carb.
Get the 600 CFM in either type. They both work well for street and light to moderate offroad.
But if you wheel hard get a Q-jet. Edelbrock makes a good Q-jet also. Model #s 1901or 1903 should fit.
<font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue><P ID="edit"><FONT class="small">Edited by Thunder on 10/29/01 08:21 PM.</FONT></P>
Here's a question, are the Edlebrock carbs made by Webber?
Im looking at mine and there's a W on it? and as far as a 750 on a chevy 350, mine work great it just the laws that suck not the carb, but i dont have a stock 350.
-Tony
-Tony
I run the Edelbrock 1902 Q-Jet. Yes I do believe them to be made by Weber. The carb works great! I am going TBI though cause I hate carbs.
Mark
1985 K5
Built 330HP crate 350, SM465, NP208, 10 bolts, Ranchos and 31X10.5 on Rallys!
You obviously don't know what you're talking about. If we're talking squarebore carbs, a 750 is too big for any naturally aspirated 350.
A 100% volumetricly efficient 350 cubic inch engine at 6,000 RPM needs 607 CFM of air. That's quite exaggerated too because few trucks if any will ever see 6,000 RPM and no motor I know of with a dual plane intake will ever see 100 percent volumetric efficiency. Especially one with stock or nearly stock cylinder heads. There's the numbers. Argue with that.
As for the Q-Jet, it adjusts the doors that open the secondaries based on load and has very small primaries. It will work very well on any engine from a small 6 cylinder all the way to a stock or mildy modified big block.
I never meant to say that a Q-Jet wouldn't work on a 350. Q-Jets are a great design. Their versitility as far as size is unmatched in the arena of carbs.
So, let me be more clear and say that a 750 CFM squarebore carb is too big for a 350 in a truck. With vacuum secondaries it could be made to work but it's still over-carbed.
I'd much rather have a carb that is too small than too big for an engine. Trucks need TORQUE, and vacuum is what makes torque. Small carbs will give better throttle response and bottom end torque. That's yet another reason that Q-Jets work well--the small primaries work very well off idle.
Tim
Hey 84',
You sound knowledgable on carb's so here's another question. 350 engine with a 671 blower, tunnel ram with 2 holly 600's. Is this too much carb for this setup? a friend told me it would "hook up" better with 2 400's? I mean would it be better for daily driving with smaller carbs due to that low end tourqe, or does it matter at this point?
Thanks
I know this much, I put a holley 650 dp with mechanical secondaries on the firebird which has a pontiac 350 (355 from the factory)bored 30 over so its 359. I put the biggest jets I had and it still ran lean. I was running 90s squared all the way around. Now I stepped up to a 750 dp w/ mech sec. and I only have to run 70 jets and it runs a little rich now, but not much. So I would say sometimes a 750 works on a 350. My redline is 6,000 rpm also. Now as for a stock 350 I wouldnt go any bigger than a 650 cfm.
86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
