gonefishin
So i am building my race truck. It’s a 91 swb gmc not square body. I haven’t measured the current wms on the 10 bolt, but I want to stay as close to stock as possible.
Anyway it’s getting a 427 stroked ls3 with a solid roller cam, 11.2 compression, ported heads that flow 390 cfm, and supercharged... and also the tr6060 transmission that is getting the t56 magnum tailshaft housing and output shaft so that it has the slip yoke.... I’m shooting for 1200 rwhp on e85.... I can’t wait to pick it up from machine shop. Also considering the holley dominator efi setup if anyone has used that let’s hear it too...
Truck should be around 3700 pounds.. I’ve been planning on a 9.5sf with dutchman 5 lug shafts (basically a 454ss rear end).
But I would love to have disc brakes... and I have read the 9.5 isn’t as efficient and will have more drivetrain loss compared to other axles... Here are the axles I’m considering..
Built ford 9 inch
Dana 60 something like a strange s60
Sf 9.5
Or what else should I consider???
Built ford 9 inch
Sf 9.5
