Stomis
Professional Amateur
I knew nothing when I bought my first one. I actually got it really cheap cause I knew someone who worked at harbor freight. Its a Chicago Electric 90 amp fluxcore welder that plugs into a 110 outlet.
The thing is basically only good for doing exhaust work and tacking light material. Its got 1-10 variable wire speed which is nice except its so weak I always have to go really slow and weave to get any sorta bead out of it. Its only got high / low for the power which tics me off.
I want to step up to something better. I'm going to tube out the back of my truck and I want to do it myself. I already know I need a better welder but I cant spend an assload of money on one. I'm not interested in brand names or anything like that because for being a cheapo this thing has served me pretty well.
I want something that I can penetrate tubing with no problem and make structural welds with for cages, tube beds, bumpers, etc without having to make multiple passes.
I know I'm most likely gonna have to go with a 220 outlet but what do you guys suggest? What amp output do I need to penetrate tubing well?
O yeah and would it be cheaper to go with a stick to get the penetration?
