I seriously need some advice. I am trying to get my 1990 k5 inspected, but for some reason when the left turn signal is activated, all the turn indicators/tail lights flash. When I turn the head lights on (hi beam or low beam) the left side turn indicators do not work (no blinking). All of the other lights appear to operate fine (whether the headlights are on or not).
I have checked the wiring (under the hood and dash) for anything that looked supsicious (PO special wiring, damaged wires/grounds), but have found nothing obvious.
I got my wiring diagram out, and trired to follow everything in the light blue wire circuit (left turn signal), and found nothing out of kelter. I have tried changing bulbs from right side to left side, and the right side still works and left side does (bulbs are not the issue (all bulbs light and flash, so I do not think the bulbs are the problem).
I am not an electrical engineer, but I am also not incompetent. I have spent a couple of hours on this, and have simply hit a brick wall.
If you have any advice, I would appreciate it.
Thanks,
Chris
Thanks,
Chris
