this is true blazinuk and the right way to go thanks, i think i have vacuum issues too, i am a little boggled at where to start on this thing
Got a repair book? get one. You might be able to go to your local library and copy certain pages out of a factory manual. Ours had one for my 73.
There is so much knowledge on this website if you find a specific problem I bet you would have a specific answer in short order.
$250: Rebuild kit for 350
$150: Dizzy/ Plugs/ Wires
$100: Fuilds/ Belts/ Hoses
A 350 is stupid simple to rebuild and the kits are readily available on line for between $200-$500. Add new dizzy from summit and replace any belts and hoses that look worn and you have a runner and a fresh start.
I wish it was that easy...
Face value looks that way until you get it apart and realize that the bores are taperd and the heads new a valve job. Once you find that then you can tripple your price tag.
My advice to you is to rebuild your carb, replace the distributor/plugs/wires, replace ALL the vacuum lines, and then time and tune the engine. I bet you'd be amazed on what a difference it can make.
Healthy engine, weak engine, neither of them are going to be happy turning 35's with 3.08 gears.
Martin
