Alright, I'm almost embarrased to ask these questions among threads regarding axle swaps or pure build threads, but hey, sometimes it's the little details you get stuck on.
I've transfered all loose parts from my old electric '88 K5 tailgate to a new, rust-free shell, and when all's said and done, there are three minor things I'm left not knowing the answer to. (If I can say so myself, not bad for a first-timer!) It's true that a fully working tailgate isn't really dependant on the answers to either questions #1 or #3, but it feels better knowing I've done a complete job, so if I could get some help with any of the following, I'd be grateful:
I found this square little rubber washer laying loose at the bottom (see attachment #1). Didn't know what it was, and since GM's official parts diagram didn't even list it as an item, I put it aside. Then I happened to see it listed in LMC Truck's catalog as a "Window Glass Bumper Stop". They also say 2 are required, so apparently I'm missing one. My question is, where do they go? Obviously somewhere at the bottom... There is one square little metal piece with a hole in it almost mid-bottom, near the lower cut-out for the lockout rod - does it go there, fastened with a screw or something? That still leaves the question of the location for #2, though.
Second question; take a look at the lockout rod spring in attachment #2. Is it supposed to have that shape or has it been bent somehow? One end goes around the lockout rod and the other in the designated hole above it in the tailgate metal, right? (Mine was laying loose on the bottom...) I don't get how that "straight" end will ever hook onto anything, but looking at both GM's and LMC's parts diagrams, it does seem to have that shape...
Last question, attachment #3. A plastic clip that hung loose on my old regulator cable. If this is an OEM part, it's not listed anywhere. It looks to have been glued somewhere to help hold the cable in position; the question is where?
Weblinks for those without a membership:
#1. http://img293.imageshack.us/img293/7433/09082007237mw4.jpg
#2. http://img515.imageshack.us/img515/7483/09092007242rp1.jpg
#3. http://img293.imageshack.us/img293/1735/09092007243fa4.jpg
