ok so I have been tinkering with my new 355 trying to get it tuned propperly. It has a balanced Eagle rotating assembly, Patriot Perfromance aluminum heads, Lunati Voodoo cam 262* intake 268* exhaust. On top of that it has a Weiand Action+ intake and a 725cfm Road Demon Jr. with Headman Elite headers to true dual Pypes Violator mufflers.
What I am having problems with is that with the new mufflers that I just put on is that once I hit 2-2500 rpm and up under medium to heavy acceleration the exhaust sound really crackily and is actually pretty deffening. The Pypes Violator mufflers are a straight though design with louvers like a glass pack. I also have a big a flat spot in acceleration occuring at about the same time through about 4000 rpm. I have already changed out my accelerator pump cam to the blue one in the #2 hole which has eliminated my off idle stumble. And I swapped in the lighter short yellow vac secondary spring and noticed an improvement but the flat spot is still there. I have not changed jets yet, I have a set on order now. Also according to the Demon carb instruction manual for my setup requires a 8.5" power valve over the 6.5" factory one. What do you guys think?
As far as timing goes because I know someone will ask, its only adjusted by ear because my accessory setup doesn't allow me to see the timing tab. Also I believe the reason the engine just falls flat on its face after 5000rpm is due to a crappy factory distributor even with a pertronix flame thrower coil and module. I have an MSD system on order now too.
