buckmtn
Want to put together all around bad ass truck for trail ridding, rock crawling and the ocassional mud pit. Probaly never see much pavement. What I have is a 89 full size blazer with 10 bolt/14 bolt detrioit locked, 350 tbi with rod knock, sm465 w/205 case, 6" susp 2" body. I have a partial dana 60, bought new rotors, drw hubs, to run h1 wheels, 35 spline warn premiums, new spindles, detriot locker,new stubs, 5.13 gears. Just picked up a set of 3/4" tread 44" tsl's. Yesterday I picked up a '86 k30 with a carb'd 454 and 4-speed w/205 case. Dana 60/14 bolt 3.73 ratio. ($1250) Mostly bought it for the motor to put in my blazer to get rid of the rod knock and have something to turn the big ass tires. Motor runs great! Now just thinking of dumping the blazer and tossing the bed off the k30 shortening the frame and run it. I'd like to switch the 454 from carb to tbi for better off road ability, but not sure how to go about it. This is getting a little long winded, sorry! Post up your ideas! Not sure which direction to go!!!
bc it is much easier on many obstacles and if it is a narrow trail just get the door handle past the trees and turn
