irocvette355
Registered Member
I was doing a brake job yesterday...while i was down there i took a look at my front axle u-joints. They look good, but, i have noticed a "clanging sound" when driving over bumps in the road.
So...i determined the cause of the sound. The driver side axle moves around in side the tube. it will move up and down about a half and inch, seems like it should be firm in that area like the passenger side. The passenger side will move a bit, which I expected, but not as much as the drivers.
Is there some ring that is supposed to support the axle at the end of the tubes?
I check the 4wd hubs, the snap rigs are on the end of the drive spindle are there as they should be.
BTW the 4WD works fine and there are no issues other then the clanging sound over bumps.
