I had 180K on an engine when I sunk it. Damn culvert collapsed when I was crossing it and the front end went under water. I winched out, but some mud got in my starter contacts and it would not crank after I got out.
The engine had been running all the time I was getting out, so I knew it did not ingest any water. I got a friend of mine to pull me home and just parked the truck.
Week later, I drained the water and oil out of the front end, and decided to check the oil before I cranked it.
There was rusty sludge halfway up the dipstick.
Water had gotten in the lower part of the engine.
I changed the oil and filter with some cheap oil, cranked it. Ran it bout 5 minutes, changed the oil and filter again. And repeated that after 10 minutes.
Then, put in my good oil.
Oil pressure looked good, no noises, so I drove it.
About a month later, I started getting worried. The engine was running fine, but it just nagged me.
So a friend of mine and I eased the engine up and pulled the pan. Pulled off one bearing cap.
The crank journal looked fine, but the bearing was toast.
Pitted, discolored, not good looking.
We wound up replacing all the main and rod bearings to keep things together until I could get time for a rebuild.
We didn't touch the journals, just put in new bearings.
I know we mic'd the crank and rods, but for the life of me I can't remember if we went stock or .010 oversized.
As usual, life happened, and when I looked around again, I had put about 50K on those bearings.
I got a deal on a blueprinted engine that a guy had had built and totaled his truck on the way to pick it up.
I gave the old engine to another friend of mine, with the story of the bearings.
He put it in his barn, poured the cylinders full of oil, poured the crankcase way overfull so that the crank was covered, and left it sealed up.
About a year later, before he had gotten a chance to rebuild it, the motor on his truck seized.
It was harvest time, and he could not have that truck down. So, he drained all the oil out of my engine, refilled it, put it in his truck, and put at least another 80K on it before he sold the truck.
As far as I know it never used any oil between changes as long as I owned it, and never did up to the day he sold it.
We both wish out loud sometimes that we had that engine back. .....
J.
