Help - Nasty Smell (lol)
SlyDog
Scottsdale, Arizona
Hey, Our 1996 yukon has this nasty smell whenever you turn on the Aircondition. My dad says it needs a new thermostat. Would that be whats causing the smell?
- SlyDog
Well, you ain't supposed to air out your arm pits with it!!!! LOL!! What's it smell like?
<A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
Might be mold.
<A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
WTF??? Paulie, aka Juan Valdez, what the heck are you doing with mold on your arm pits?!?!
Dont you ever take a shower and use soap?
When In Doubt, Whip It Out!
Smells like milk but we havent had milk in this vehicle at all ! And you only smell it when the ac is on . And NO it is not my armpits . . . Pull your head out of your's and stopgettin high off the fumes ! LOL !
- SlyDog
Don't use the A/C!!
Seriously, it probably is a little mold/mildew growing in the ductwork. When I lived in CA I had this same problem with a Plymouth Laser. I bought this stuff you sprayed into the vents and the intakes for the HVAC and it cleaned them out. Worked pretty good, too. Unfortunately, I've never seen anything like that since...
Semper Maintenance!
There is a problem with mold growing in the evaporator on A/C systems. It will need to be cleaned out. The mold starts when the moisture in the air condenses on the evaporator and then you shut the car off. You then have a dark, enclosed, moist place for mold/mildew to form. To prevent this in the future you should turn the A/C off a few minutes before you arrive and just blow the vent from outside to help dry the evaporator before you leave the car.
Josh
In addition to cleaning out the A/C system from moulds, most newer A/C systems need to be "purged" by running them in the "vent" position for a minute or two before shutting the car down. A friend of mine has a foreign car that has an A/C system that smells like stale urine when she doesn't purge the system.
Spray Lysol(sp?) in there....it works. My Neon gets that funky smell sometimes and my friend who has one too told me to try that and it worked great. Killed whatever it was stinkin' it up....!
"Suck Fumes Ford Boy"
"I love my country, I fear my government"
<A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
