help: need longer E-brake line
muddybuddy
1 ton status
Northern, VA
hey guys, i just put an 8" lift on my 88 k5 and the e-brake cable is real tight. as it is now, its so tight that i can not put the parking brake on.
Can somebody give me a part number for advance auto or auto zone for a cable that will work?
thanks guys, all help is greatly appreciated!
I donno 'bout the new ones, but I just fabbed an extension to the middle coupler, gave me enough. Granted, I only did 4" and my p-brake setup is different than yours ... but it's a thought.
Otherwise, pm Desert Rat here and ask him about the place he found that does custom cables.
-- A
alright, i guess ill try to fab something up, unless somebody who hasnt replied yet has a better idea, im hoping :D
I used (I don't know what it's called so I'll try to describe it...) a ring used for joining two pieces of chain. It has a threaded colar that you can unscrew to put the cable in and then thread the colar back up to close the gap. It was perfect for my application as I only needed an inch more to make my cable work.
Maybe something like a turnbuckle might work for you?
