Help. need th350 dipstick length!
diablo1
colorado
I changed the filter and fluid on my tranny and added 6 qts and still not showing on the stick. I know 6 qts did not come out so either the fluid was low to begin with or the dip stick is to short and not for my tranny.
Thanks,
Brian
Brian, I'll post up something about 12 am EST, when I get home from work!
Mine is 27" seat to tip, and 1.75" from tip to "full hot"
There are several different lengths of tube and sticks for a TH350 trans. I would recommend replacing both the tube and stick with a new one so that you know the tube AND stick are a matching set.
do what scott said.then at least you know its a matching set.i got a chrome one for under 20 bucks in the dress up section at the parts store.
Thanks for all the replies. I may just have to go that route. Would any of you have time to get a tube measurement length to go with your dip stick measurements?
my tube was about an inch shorter than the measured length of the dipstick
