HELP: Need torque specs for transfer case please
DieselWarrior
LowBuck-LowTech
I am getting ready to tear it down and put new gaskets and seals in. If you have the values please respond with RED= BLUE= etc.. (KISS, since Im stupiiiiid).
I can put it back together and snug the bolts, torque them when I get the info.
THANKS MUCH!
Andrew
How to keep cool in the blistering heat and baking sun... Got on sale at Dick's Sporting Goods, around $60!
A pic of the D-Day Memorial in Bedford, VA (an hours drive for me), thought Id post it since Im retired from the 29th Infantry Division, 1/116- the same unit that was first to land-
Andrew
I honestly have never actually torqued any t case bolts before :dunno:, I always use some blue loctite, and try to tighten them in a crisscross pattern. Don't go crazy since it is only an aluminum case just use German torque- "Goodentight" ;)
On a side note I have that exact same canopy from dicks, we use when we go to the races (four wheelers ) or sometimes for cook outs :D
just remember, all fasteners have a torque spec based on grade and size... most 3/8 grade 8's are in the 30 to 35 lb range.. grade 5's down around 25...
iirc, all the bolts pictured are 3/8-16..... I would say 30 is fine.. personally, I just went with the German method..
here's a bolt torque chart....
http://unlimited-usa.com/ConversionChart/
Dank! Goodntite!
Actually, I think Ill go with 30ftlbs and be off with it!
Just got back from Auto Zone, the gasket kit I got was wrong, and expensive... so I returned it for some grey RTV (Permatex) and engine degrease.. :waytogo:
I hope to have ready this evening..
THANKS MUCH!
Andrew
Wheeeeeee!
Transfer case is FINISHED!
All new seals and 100% new Permatex at all mating surfaces.
It was near as bad as I thought it was going to be!
THANKS MUCH EVERYONE!
Andrew
