HELP PLEASE
Was putting my new 14 Bolt Pinion (Yukon Gear) in the carrier. Inside bearing went on zero issues. Crush sleeve eliminator installed.
Was on my third attempt at setting Backlash and was pressing Pinion out of carrier to add more shim.
The pinion came out easy each previous attempt easy peasy
This time IT WON'T BUDGE. Full 12tons of pressing and it won't move. There is nothing keeping pinion from dropping out of carrier. I have an easy 3" of drop room. I used MAP Gas and got the outside bearing good and hot.... Won't budge. Let it soak overnight with penetrating oil... Won't budge. Swapped out for a NEW 12ton bottle jack... Won't budge.
What coulda gone wrong. Should I jump up to 20ton bottle jack?
More heat??
I'm about to whip out my dremel and try to cut the bearing inner ring the best I can. I'll just be careful so I don't nick the pinion splines.
Here is what I'm looking at.
I have two Dana 60 rotors stacked that give me room to drop out the pinion. I just want the pinion out. I'll start over with another bearing... Just want this one out.
More heat??
