icemaneric1
Registered Member
Ok take it easy on me guys as I'm still learning this TBI system, don't flame me if I ask a stupid question when I'm done.
So I failed the CA smog test. I passed the NO test with plenty of room to spare. The hydrocarbons, now that was a different story.
Alright onto the truck, its a 91 K5 350 CA truck
Rebuilt engine maybe 150 miles on it. New Plugs, wires, cap, rotor, coolant sensor, water temp sensor for gauge, new T-Stat new oil pressure sensor, TBI gasket, intake manifold gasket. before assembling I cleaned out the egr passages.
All of the above items but had a lower Temp T-Stat (175)
first test I passed the emissions part failed the visual.
@15mph HC max 112 measured 112
@25mph HC Max 92 measured 92
Second test. All of the above items with a new T-Stat (192) Used ignition control module, used electronic spark control module, used map sensor and a used TPS sensor but still have high HC readings.
@15mph HC max 112 Measured 114
@25mph HC max 92 Measured 88
Smog tech said it also failed for not having a specific cat. Looks like a hanger to me but he said its an air injection pump tube
Anyhow, I have checked for codes and it only gives two codes 12 and 42 EST circuit.
I was doubtful of a vacuum leak being that the Nitric oxide NO readings were low, but I went on a head and checked for vacuum leaks. Unplugged one hose at a time, then all together installing one at a time but no dice.
I had a spare ignition control module and map sensor so of course I popped those in. I also tried two different electronic spark control module from a 92 and 94 but not change.
Here are the symptoms. While driving for over 15 minutes the service engine light comes on and stays on until you restart the truck. It doesn't idle smooth like a V8, it feels. The exhaust note sounds like its running lean. If you push the gas pedal revs pick up and idles smooth with no hesitation. Push on the gas pedal just enough for the rpm's to change and they increase but seems to stumble for a second or soo. I replaced the TPS with a spare used sensor because of this but that also did not change.
My questions How common is it for the electronic spark control module, ignition control module, or a map sensor to go bad? Could those parts cause high HC but not effect the NO (PPM) test? Could a incorrect cat cause high HC but have low NO?
Is there someone local who could help me. I'm in Modesto CA about 1.5 hours south of Sacramento, or 1.5 hours east of San Francisco.
Sorry for such a long rant, but I'm getting desperate here.
.Anyhow, I have checked for codes and it only gives two codes 12 and 42 EST circuit.
