Streetgliderx
i just nailed a set of 2 15" MAs in box with 2 6x9s in box and 1 amp with 1000w+1000w on it and 1 amp 800w, also a deisel audio capacitor... it was all still wired - cap how do i hook this up and do i need an extra battery? i already have a small set of old 12"s and a 300w amp back there. power fed thru 10ga wire should i up all this??? i am VERY GREEN ON STEREOS thanks
! I wouldn't recommend any smaller than 2ga, 1/0 is preferable (big enough to power everything and relatively easy to route around under the carpet). Ditch/sell the capacitor and buy a good deep cycle battery (optima yellow tops are my pick). Run your (fused) power wire direct from the battery to a fused distribution block (redundancy!) and then you can bump down to a smaller gauge wire for the amps. I would still keep this as large as possible...use a crimp down post or ring terminal to avoid stuffing a bunch of wires under the terminals. You shouldn't need an extra battery but I'd test your charging system before the install to make sure your alternator can handle it! Sounds like a nice setup, I think you will enjoy those subs
