Help on tranfer case
Yes if it is the proper input case (32 spline) and if you have the correct adapter.
That i don't know but if you search in the for sale forum you might find someone selling an input shaft or possibly a complete 241 cheap enough. You might also ask your local trans shop if they either have or know where to buy the correct input shaft.
There are many people who will tell you that 700R4's are junk and to keep your TH400. I run a built 700R4 with no problems. However, if you decided to swap in a 700R4 then you will have more things to change like driveshafts, crossmember, and you'll need to do something about making the TTC work correctly and also install the proper bracketry for the TV cable and make DAMN SURE it is set correctly or you'll toast a 700 real quick.
What are you looking for? There are plenty of places that have rebuild parts for them.
