crazyorigin
Registered Member
I have found a parts truck for cheap, it has a pair of what i am 90% sure is a pair od Dana 60's and an NP205 case. The truck is a 78 or 79 Ford 1-ton. The front axle is not a High Pinion.
Are the front non high pinion axles basicaly the same ad the High Pinion ones besides the pinion position? I plan on gutting the axles and replacing evreything with good aftermarket pieces, i just want to make sure if i get these they are not gonna be crap. The last chassis/drivetrain i bought turned out to be some old junk not any better than the 1/2 ton axles under my truck now. The axles and t-case will be going under my 87 project, hopefully a dovorced t-case too.
I have been searching for a Chevy/GMC truck with the axles, but cannot find any for as cheap as i'de like. I dont mind having to fabricate the mounts for these, and have been thinking of doind a custom suspension anyways, i have lots of time =P The truck i found is cheap, i figure as long as the front axle isnt total crap.
Thanks for any help, before i drag this thing home i want to make sure it will be worth it this time.
