Help removing heater core.
Blazer79
Guatemala, Central America
Hi guys.
So I start tearing up everything to remove my leaking heater core. Started with the glove box and then removed one of the bolts that hold that big plastic cover. Surprise, the rest of the bolts have round heads! How do I remove them?
Any help greatly appreciated.
<font color=blue>//////
http://blazer79.coloradok5.com
</font color=blue>
if i am remeambering right you only get 2 or maybe 3 from inside the cab and the reast are from the outside on the fire wall hope this helps. good luck
s.smith 77blazer lookin 4 mud
There are 3 bolts in the engine area. If you have AC there is one behind the distributor, one just above the heater core hoses, and one below the AC on th fire wall. The last one can be a pain. You don't neccessarly need to disconnect the cable for the control, but 2 vaccume hoses. But be careful, somethings might be brittle.
Just changed mine a few weeks ago. Inside the engine compartment I actually removed 3 nuts (not bolts). If your setup is similar than the round head bolts don't have to be removed from the blower housing inside. Once you pull the nuts you should be able to wiggle the housing under the dash until it frees up. Don't know if that makes enough sense to help!
<font color=orange>STEVE<font color=orange>
89 Blazer
67 Camaro 468
68 CamaroSS 327
98 GTP
The "round head bolts" are similar to carraige bolts and you don't need to take them out from the inside. Just remove the nuts on the firewall in the engine compartment. I had a hell of a time trying to get the core out of the heater box. I managed to squeeze it out but it wasn't easy! It seemed like you had to disassemble the doors to get it apart but I couldn't figure out how to do so without damaging them. Take your time be careful as things in there are quite delicate. Good luck!
