Help removing old bearings
bigred88
Divide, Colorado
I'm in the process of changing out my sway bar bushings, but one of them is stuck. One of the ones on the end, with both rubber and metal, and I cannot get it out of the hole for the life of me. I've tried everything I can think of, and nothing has worked. Any ideas?
One more thing I forgot- is it ok to drive a stock suspension K5 on the highway with no sway bar (since it's my only mode of transportation, and it may be a little while until I can get the sway bar back on)?
Yes, it's safe, it'll just feel a little different than what you're used to. I went out to look at one of the sway bars in the scrap pile (I don't use them), and it looks like you could push the inner sleeve out with a 3-in-1 (big c-clamp for u-joints and ball joints) or socket and hammer, then cut the rubber bushing or push it out with sockets and vise.
That said, I haven't found any use for the sway bars unless you have a camper on, and I like the ride better without it.:D
