tch777
So I pulled the IAC out. Looked a little cruddy so I gently took it apart and cleaned it. Used a little Hi temp grease to lube a reassembled.
Then I found the minimum air setting procedure here and warmed the truck up to operating temp. Shut down and jumped the A and B terminals on the ALDL for 30 seconds. turned the ignition off and pulled the IAC plug and the jumper restarted the engine and got it back into closed loop according to WinALDL and set the idle down to 400 rpm and it idled pretty good. And I had to turn the idle down it was up at 525.
Turned engine off and plugged in IAC tried to start truck and it was still idling at 400.
What did I do wrong?
