87 Blue Beast
just put a cam in a 350 and im having a little bit of a problem. first off, the cam was a comp cams XE268H (268 int dur, 280 exh dur, .477 int lift, .480 exh lift, 110 lobe seperation). the motor ran perfect before we swaped the cam. so heres the problem... i had my dad crank the motor while i played with the distributer. we got it running and it idled and sounded good. after having it running for a couple minutes, i threw a timing light on it to see where it was at. turns out it was somewhere around 20* at idle (but there is no pinging) which seems like way too much since its supposed to be somewhere around 8-10*. so i cranked it back to 10* base timing and it wont idle for crap. it wont even run below 1200 rpms and it stalls as soon as you put it in gear. i hooked up a vacuum gauge up to it and it pulls 16-17" at best at 950 idle (when the timing is jacked way up, since thats the only way it will even idle). its running rich. its the same carb setup that was on the motor with the stock cam, so obviously it needs tuned. but wouldnt a bigger cam cause it to run more on the lean side apposed to rich using the stock jets/settings? is it possible that it needs more timing since its just running so rich? could the carb be causing all this trouble? i just dont know where to start...
heres a link to the cam card if you need more tech stuff http://compcams.com/Cam_Specs/CamDetails.aspx?csid=86&sb=1
. maybe it is possible that it needs that much timing like some of you said. if thats the case, ill take it up to 3000 rpm with the light on it and if it doesnt go crazy, ill let it like that. if it goes to like 40* or something, ill just unhook the advance and run it without it. btw, i believe i read somewhere that this cam has 4* advance built into it. does that mean 4* timing advance or the lobes are 4* advanced... like degreeing the cam 4* ahead?
