OK , I have a 1989 k 5 with a 350, I was driving home one day and the truck cut out on the highway, pulled over and it restarted, went about 1 mile and it did it again it would start for a sec then die shortly after i needed a jumper to get it to start then it just would die.
Next i get it towed home , tried to start it there and it wouldnt crank at all , since parts are somewhat cheap(compared to my boat
) , I decided to put a new starter battery and alternator in it. Feeling confident I crank it over and 3 times each time giving it a min and on the third crank , it just died and would not crank at all , like it was a dead battery or started went bad.
what i found next was wild the, the service engine light was on even thought there was no key in the ignition and the ignition was in the off position. for sometime before all this the battery would be dead and i would have to jump it i put a battery maintainer on it since i dont use the truck all that much. but im not sure if that was leading up to all this , I BEG for help since i rely on this truck in the winter to get my wife to work when it snows " shes a nurse so if u help me ill put in a good word if you ever need her assistance
, lets hope you wont though ,,,,, look forward to anyones help THANKS GUYS !!!
) , I decided to put a new starter battery and alternator in it. Feeling confident I crank it over and 3 times each time giving it a min and on the third crank , it just died and would not crank at all , like it was a dead battery or started went bad. what i found next was wild the, the service engine light was on even thought there was no key in the ignition and the ignition was in the off position. for sometime before all this the battery would be dead and i would have to jump it i put a battery maintainer on it since i dont use the truck all that much. but im not sure if that was leading up to all this , I BEG for help since i rely on this truck in the winter to get my wife to work when it snows " shes a nurse so if u help me ill put in a good word if you ever need her assistance
