I was in the process of swapping the steering wheel, and noticed the nut to remove the wheel was rounded off. So my next steep was replace the whole column. I swap the column, and put a new key switch (bought the good column off some stranger). After swapping this stuff I noticed the only way to get the truck started was tilting the wheel up and down then it would start. Sometimes the key switch is hard to turn some times its smooth. After a couple of weeks it took longer and longer to get started now it will not start. When I turn the key theres nothing like if theres no fire going to the starter also the fuel pump does not come on only sometimes. I check all the connections on the started the battery.
