Swampy79
Registered Member
I have the opportunity to get the proflo vicjr manifold w/ injectors, fuel rails, and the 1000cfm 4barrel. It does not have the ECM, wiring harness, or anything else that came in the full kit. Is it worth it? I can't seem to find out if I can order just the ecm and a wiring harness with the hall effect sensor or if I have to buy a complete package. The description of the Pro-Flo upgrade kit on summit says that wiring harness is not included? Anybody know any different?
The injectors don't care what computer is hooked up to them, but the computer needs to match the injector impedance.
Heck I even used a V6 wiring harness, except I modified the V6 injector harness to fit the Vortec V8 injector harness. Most importantly, I programmed the PROM myself.
