I'm running a stock 28 spline 10 bolt front axle w/ a lockright locker on 37's and I carry spare axle shafts just in case
. I want to know what the "procedure" is as far as what to do in the event that I break something. I carry all the necessary tools to break down the front axle. But I've never wheeled w/ lock-out hubs before (auto hubs on my TJ) I've swapped plenty of dana 30 axles on the trail (never mine tho
) and I was wondering what advantage the lockouts give me in the instance that I do break. Can I just unlock that side and continue, or will I need to replace that shaft ASAP? I'm pretty easy on the pedal - I'm more of a pick-ur line kind of guy than a mash the gas one. I do encounter rocks tho, and just want to be better prepared when something does snap. Chromo shafts are in the near future, but I'll still be wheelin before that happens.
