Help w/trany adaptr
Thirdminor
Registered Member
Panhandle, Fl
I am swaping my th400 for a 700r4. I have a np203 (2wd con) that Im going to use. I just dont know what adapters I can use. Will one for a th350-to-np203 work or others?? please help
86 8.2 banks stock, 84 cucv 8"spring frt 4" spring rear w/ ord shackle flip 38" boggers
This is confusing. I'm not sure what you mean by "(2wd con)" but in order to put a NP203 behind a 700R4 you need a TH350/NP203 adapter along with either a short shaft installed in the 700R4 or a spacer and the NP203 needs to be a TH350 version.
