Help with 14 bolt 10.5 ring!!!!!!!!
PineyPower
New Jeresy out in the pine barrens
I need a digram of the inside of the carrier showing all the bearing and stuff.I really need to know what bearing i need if anyone could help me out i would apprite it.
Aslo got a dana 60 rear axle for sale 4.56 gears locked everthing make offer.
which bearings do you need? The carrier bearings on the ouside of the diff? or the pinion bearings?
Brian
82 burb
40" TSL's D60/14FF SM465/NP205
<font color="green"> You need the pinion? You know that ring and pinons are matched sets, right? You can't mix and match them...
I have a full set of bearings for my 14b at home right now, I can look at the pinion support bearing tonight and tell you what the timkin part # is. </font color>
