billyjo
Registered Member
After having the parts do to my 14 bolt rear disc brake conversion in the box for over a year I decided to do the swap last night. I bought the kit from Off Road Unlimited and downloaded the instructions before I started.
Everything was going easy and I couldn't figure out why I had waited so long to do the conversion (should've knocked on wood). I tried to put the caliper on and it wasn't opened up wide enough
so I messed around with it for some time before I decided that they must've send me the wrong spacers because even if I could get the caliper with the pads over the rotor it wouldn't line up with the bracket.
I went back into the house a little disappointed to say the least, then I thought about it some more and decided to try the other caliper. Guess what??? It fit perfectly so they sent me the wrong caliper for one side.
The caliper that works is a delco moraine with a number of 6473499 casted into it. I've tried looking that number up online and can't find it. So does anyone know what caliper I need for the other side or what make of vehicle ORU uses the calipers from? I'll just go and buy another one if I can figure this out so I can get my swap complete.
Any help is greatly appreciated,
Bill
so I messed around with it for some time before I decided that they must've send me the wrong spacers because even if I could get the caliper with the pads over the rotor it wouldn't line up with the bracket.I went back into the house a little disappointed to say the least, then I thought about it some more and decided to try the other caliper. Guess what??? It fit perfectly so they sent me the wrong caliper for one side.
Bill
