carolinafan4life63
my transmission went out last week .........well all gears except for 1st and reverse! my new one that i ordeed from jasper will be in monday morning. I just pulled the old one out and pulled the pan and found something interesting that hopefully someone can help me with. the electrical plug on the side of the tranny only has one green wire coming out of it going to the brake pedal switch.(had a thread about this a while back also)
when i pulled the pan i noticed that the black wire (ground , i assume) was cut and grounded to a bolt on the valve body , anyone know why the previous owner may have done this?? also the servo at the rear of the tranny , right in front of the transfer case has a little plastic gear on the shaft that runs of of the trans output shaft , it is shredded and broke in half. Please help me with some info before i install a new one in the morning and screw it up!! my cell number is 803-383-4261 , i can explain it a whole lot better if some of our more knowledgable tranny guys would give me a call. thanks, john thigpen
