Help with a couple things on my 72’
Spikes72
Registered Member
Imperial Valley, Ca
The odometer isn’t working and the MPH is a little jumpy.. any suggestions?
I’m trying to seal up the doors …. Seems like it’s going to be a moist winter n the desert. I’ve been looking for the rubber thingamajig that mounts to the top of the vent window/frame… see pics
All help and suggestions are welcome
You could try removing the driven cable from the cable housing and cleaning it with some break clean and a rag, then apply graphite to the cable as you side it back. Spin cable as you do this.
Remove cable housing from back of speedo head, this can some time be done from under the dash, or you can loosen the instrument cluster enough to reach the housing attachment.
Sorry no recent experience, with gen1 k5 weatherstrip, other then recommend the brand name Precision.
