MEMO43
Ok rig is an 85 Chevy k20, I have developed a shaking/pulling when the brakes are applied. Almost as if I have a warped rotor?
Not sure if it could be the MC or proportion valve.
Everything else has been replaced last Aug.
I replaced wheel bearings, calipers, rubber hoses, rotors, brake pads.
For the rear I replaced the rubber brake line, wheel cylinders and brake drums and hardware and new shoes.
Front suspension is new as well, The reason I did all this when I first got the truck it sat parked for over 5 years due to bad ball joints on the passenger side.
I still have the original MC, proportioning valve and that weird load sensing valve out back.
I've done manual brake bleeding, vacuum bleeding and finally got the kit to that pushes fluid through the MC out the bleeder screw.
Also to replaced all shocks due to one of them have developed a leak, went with Bilstein's.
Can a failing MC cause the shake/pulling or the proportioning valve
This one has me baffled.
