Ok, so my cruise control has always worked, well up until I finally had to tighten my own tilt steering column. I had to drop the column down some in order to fish the turn signal wires up enough to get the switch and the housing over the steering shaft. When I was all done I discovered that my cruise control no longer works. I thought maybe I pinched the wire coming from the set button on the end of the turn signal switch but I have checked it and it is not shorted out and I do get continuity between the wires when I depress the button. I also thought that maybe I accidently knocked a wire loose from the DRAC module but that wasn't the case, I also checked the switch on the brake pedal and that is all looking good and the electrical wiring is still connected and the switch is adjusted properly. Anyone have any other ideas and what/where to check? I've checked every fuse and they're all good as well.
