RJB44
Hi - I need to replace my directional lever for 1991 Blazer. The lever is cracked. Although it still functions for directional and wipers, the hi/lo beam function does not work. When I pull the lever in, it is loose, with no tension. I assumed it was because of the plastic crack in the lever housing, so I ordered a new lever. However, when I take the cover off, I cannot see how or where the metal rod that controls the hi/lo is attached to the lever. I can follow the rod all the way down to the switch, which works fine. I have attached pictures of where I am now, including the new lever I have. I would appreciate any help on this, as I am do for state inspection next month. Do I need to order an additional part? It does not look like the new lever alone will correct the problem.
