Hi,
I have a 1988 K5 with TBI. Occasionally, my check engine light will come on after driving on the highway for 30-45 minutes. After I drive on the highway, and pull off to a stop at a light, the truck will occasionally shudder and vibrate heavily, unless I give it a little extra gas to boost the idle speed. After I turn off the truck, and turn it back on, the light will go away. After checking the codes, I found that it was displaying Code 32:
"Barometric pressure sensor failure. EGR valve diagnostic switch closed during engine startup or open when EGR flow requested by ECM".
Today, I failed the emissions portion of the state inspection. This truck had passed the last 3 years in a row without any issues. I suspect that these two problems are related. Does code 32 indicate some sort of vacuum leak? Please advise where I should begin trouble shooting this problem.
Thanks!
Thanks!
