help with finding a short with a mulitmeter
tfitch03
Registered Member
Dallas
I have a gage/idle fuse that keeps popping. I have read a lot on here about what it could be and after much troubleshooting I think I might have a worn wire in the group that goes behind the distributor from passenger side to driver's side. Can anyone explain how to check the ohms on each wire with my multimeter or show me a current write up about this OR tell me a better way to check the wires? There is ZERO room to work back there without taking off the top of my engine :doah:
It is a 1990 V2500 Suburban, 4x4, 350, injected.
Your meter has a continuity setting that "buzzes" when the two probes are touched together (complete the circuit) correct?
If you think you have a short to ground, you find one end of each wire you need to test (such as the ECM connector if that wiring is suspect) and you simply connect one probe (does not matter which) from the meter to ground, and touch the other probe to whatever wire you want to check. If the meter buzzes, the wire is connected to ground.
If there is a short to ground (or it's a ground wire, you need to have a wiring diagram to make sure, but normally pink, orange, or those colors with a stripe are not grounds, all other colors are up in the air) the meter will buzz. You must make sure you have a good ground though. I prefer using jumper wires with alligator clips on them for the ground side, so that it frees up a hand. I also always check my meters ground by touching ground somewhere else on the vehicle, to make sure the meter works as it should.
A wiring manual diagram would help, because you can use that to determine what circuits that fuse feeds, which will help you find the components where you can test the wire at the connector.
Do not puncture the wire jacket with anything to test, that allows a path for corrosion to form. Test at the factory terminated ends (or factory splices if there are any) only.
Make very certain that you disconnect the negative ground wire at the battery and touch the positive and negative wires together at the battery afterwards to discharge any residual electricity before you do, then leave them apart.
Ohmmeters do not like powered circuits.
