WJACKSON11X
Finally got everything hooked up for hydro assist including a cooler and remote reservoir. I started the bleeding process with truck off and draglink removed. Started truck up and immediately the steering wheel started turning by itself and ram extended. Now the ram will not move either direction and steering feels tight. I've got the endcap and top cover tapped with the endcap hose going to side of ram that is closest to the end that moves (if that makes sense). If the lines were reversed, would it cause these symptoms? It's a brand new pump, hoses, and cylinder with 8" stroke. Ram is not mounted to tierod, just hanging.
