Help with my buddy's 1998 4.3L S10 - turns over but won't start
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
My buddy has a '98 S10 2wd with the 4.3L.
In December I helped him give it a general tune up as it's 100k+ miles. Was reliable but had a little stumble/miss every now and then. We did plugs, oil and filter, airfilter, and plug wires but he forgot to get the distributor cap and rotor. Put everything on and it ran much better and he said the miss/stumble/whatever was gone.
Few weeks later he gets the rotor and cap and puts them on himself. Immediately he says the miss is back. Keeps reporting it's worse. He's kind of wondering if he had damaged a plug wire because he said he had to kinda reef on them a bit to get them off the dizzy.:dunno:
Lately he's been saying it's even worse and was getting worried. Last night he drove a few miles to get his son, turned it off, came out a few minutes later, turned it on, then drove to the corner where it stumbled and died as he came to the light. Couldn't get it to start and had it towed back to his place.
Says you can hear the fuel pump when you turn the key on and the engine turns over but it just won't catch.
Coworker has suggested the ignition module dohickey the Vortec engines have on the distributor might be the culprit. Says they fail a lot.
Any thoughts?
He said it is making spark and the fuel system is pressurizing. Checked last night.
The diagnostic link is usually a good place to look. Even if the SES light is not illuminated, the VCM might have some good information to point you in the right direction.
If nothing comes up, a good place to start, is cleaning the positve leads with a wire wheel or some sort of abrasive, and applying a light film of dielectric grease to the terminations(eyelets). Too much grease will result in a bad connection. There are 2 leads. One to the starter, and one to the VCM.
BTW, I own a 2002 S10 with 200,000+ miles on it. It runs great, but over time, I've ran into similar situations as your buddy, 90% of the time it was a bad positive connection.
It has fuel and spark? Pull a couple plugs and see if they are fouled, could be the spider injector is dumping fuel... or even a coolant temp sensor that crapped out.
i,ve installed cheap wires once and the guy couldn,t make it home! it was a rainy day and fire was running all over them. try and soak it down with a spray bottle filled with water,if theres something shorting you will find it! spray the coil ,wires and around the distributor. do they have a noid to check injector for pulse? check plugs maybe flooded bad!
Last night he pulled the dizzy cover off and the rotor had literally fallen apart. The rotor he bought new and installed around Christmas time. Yeah quality parts!
Says it looks like the metal had literally snapped in half at the edge of the plastic.
That might have something to do with it.
Says it runs but isn't running well and is throwing a SES light. I'm going to take my code reader over there soon and see what it's saying.
Oh, and does anyone know what the fuel pressure should be? He said it was showing 53lbs.
I went over and we scanned the codes. Showed a P0102 MAF code. We pulled his MAF and it was fairly grungy. He got a new one and now says it runs just fine.
He's talking about replacing the fuel pump and filter anyway.
