Thank you all for your replies,
JBS Conversion SYE was installed into my NP 241C with VSS, I received the transfercase with a crack in the front half, I got a replacement and transferred everything over and found the input shaft sprocket like it is in the picture.
I cant find anything that is missing in the NP 241 diagram's or from the pictures I was taking while I took it apart. I did put on the other half, rear half of the case without sealant and It went on very easily and flush with the front half.
How may the assembly of the rest of the case help in the miss alignment of the main shaft sprocket?
I really need to get this resolved. On Saturday I will insert picture of what is in there for you all to tell me what is missing.
But, Thank you, Thank you, Thank you all, for your help
Ed
