BlaZeus
The Real Mateo
So I just picked up this 56 Willys with twin sticks. How does this work? I've done a little bit of research and haven't really found anything that tells me what position they need to be in to drive on the street, casual trail, or hard core wheeling. It also has Toyota axles under it and there is a spherical bearing type deal where the knuckle meets the axle and both sides have a ton of fluid on the end of the axles. Does this mean blown axle seals? Any wisdom is appreciated! Thanks!
