like the title says i am trying to remove the hub assembly from the spindle looks like the bearing fused its self to the spindle. dose anyone know how i would take that off. i tried hitting the rotor and using a pry bar with no luck. any suggestions would help. can i unbolt the spindle from the nuckle without removing the rotor?
when i took out the spindle nuts the bakc of the bearing fell apart but the rollers stayed in place....
thanks
isaac
when i took out the spindle nuts the bakc of the bearing fell apart but the rollers stayed in place....thanks
isaac
