BIG*RED
- Joined
- Mar 14, 2003
- Posts
- 1,094
- Reaction score
- 0
Hey guys, i have an oddity with my steering wheel that has got me stumped...
Sometimes while driving straight down the road the my steering wheel is in the 12 o'clock position...straight up, as it should be. Sometimes while driving down the road it is in the 3 o'clock position while driving straight, sometimes while driving down the road its in the 10 o'clock position while driving straight.
it does this as i drive. the more right turns i make the farther right it stays while driving down the road, same goes for left turns. it actually sits in the 12 o'clock position the least amount of times.
its getting really annoying as it has at times been 90 degrees off of center, i also noticed one time that i had some "delay" in the steering wheel, meaning i turn the wheel what i would consider "quite a bit" before the tires turn.
I have replaced all 4 balls joints, both tie-rod ends, and tie rod, both drag links, the draglink sleave, the pitman arm, and the power steering gear box. and blead the system. and steering wheel is tight on the colum. and i have aligned it twice, both times it was good, and just needed a minor tweek on the toe. and i can let go of the wheel while driving straight, and hold a straight line.
so what gives? why wont the steering wheel stay in the 12 o'clock position while driving straight?
oh yeah, its an 82k5, standard powersteering (meaning, not a hydro assist or anything like that) on 37inch tires
