Chevy454CUCV
Registered Member
its been a long time since I’ve set timing on an engine And I wanted to see if you guys could help out with any tips!? I’ll try to give you as much as I can about the engine and set up. I have a timing light I got from the part store but not sure what degrees it should be sent to? Any tips on process to get timing set? It runs now, starts up decent but I’m sure it’s not perfect and want to dial it in.
Engine – 454 bored over 30. Forged crank shaft. Howard’s cam but not sure which is in it, I did not install it. Scorpion roller rocker arms. Flattop pistons with gm 7/16 dimple rods. GM to 15 kids with square port exhaust. Valves are 2.25 - 1.88.
Taylor spark plug wires with ngk plugs.
MSD 6AL With HEI Accel disto
quick fuel technology 750 mechanical secondary, Electric choke.
Sanderson headers 3” exhaust to 2.5 pipe with flow master 44 series mufflers.
2.5
Turbo 400 trans
456 gears 1 Ton axles detroit lockers front/rear
Let me know if you need any more info, appreciate any help!!
2.5
Turbo 400 trans
